Jul 17th, 2024, 6:27am
RF antenna model in verilogA (Read 148 times)
Pavel
Lausanne/Switzerland
Jun 12th, 2007, 1:22am
Hello
I have problems modelling RF antenna.
Here is code:
module ANTENNA (p1, p2, mag_field);
inout p1, p2;
input mag_field;
electrical p1, p2;
magnetic mag_field, mag_induct, mag_flux;
//Coil geometry description
// Coil inductance innH
parameter real L = .....;
// Coil area in m^2
parameter real S = ....;
// Angle between magnetic field and normale to coil plane
parameter real alpha = 0;
analog begin
	Phi(mag_induct) <+ `c_MU * Phi(mag_field);
	Phi(mag_flux) <+ Phi(mag_induct) * S * cos(alpha);
	V(p1,p2) <+ ddt(Phi(mag_flux));
	V(p1,p2) <+ L * ddt(I(p1,p2));
Coil geometry description, coil inductance and coil area calculation I bypassed as this is not significant vis-a-vis of problem.
As you could see from code, antenna coil has 3 ports - 2 electriacl p1 and p2 and one magnetic - mag_field.
Ports p1 and p2 i use to connect antenna coil to circuit, whereas mag_field I use to connect it to generator of magnetic field. The output of this generator has also nature magnetic.
In my schema I connect model in parallel to some capacitance and do transition simulation in ADE (Analog Design Environment).
The problem is that LC tank induced voltage isn't dependent on value of capacitance.
What is wrong in my verilogA description?
Pavel.
Re: RF antenna model in verilogA
Reply #1 - Jun 12th, 2007, 3:57am
Pavel wrote on Jun 12th, 2007, 1:22am:
I don't see any MMF() access functions.  Electrical has V and I; magnetic should have Phi and MMF.
Usually when I see a flow_access_function (such as Phi()) on the RHS, this means that you are measuring the flow, and I expect to see a potential contribution.  Here, you are both measuring and contributing the flux, so from a simulator standpoint, I'm not sure what your unknowns are.
Pavel
Reply #2 - Jun 12th, 2007, 4:14am
Thank you for response, Geoffrey
How can I implement MMF() in my code. It has no relations with electrical natures (voltage or current).
Pavel.
Reply #3 - Jun 12th, 2007, 9:38am
You have an equation for the inductor V = L ddt(I); I expect to see MMF(mag_??) <+ some expression of Phi(mag_??) or vice-versa.  But I haven't worked with magnetics, so my expectation may be wrong.
Another thing you could try, if you're fairly sure you've got all the constitutive relations correct is:
	  real phi_induct, phi_flux;
	  phi_induct = `c_MU * Phi(mag_field);
	  phi_flux = phi_induct * S * cos(alpha);
	Phi(mag_induct) <+ phi_induct;
	Phi(mag_flux) <+ phi_flux;
	V(p1,p2) <+ ddt(phi_flux);
Pavel
Reply #4 - Jun 19th, 2007, 6:47am
Geoffrey, you were right
Finally this code seems to work:
// VerilogA for OUT_STAGE, COIL_RECT, veriloga
`include "constants.vams"
`include "disciplines.vams"
`define c_MU 4*`M_PI*1e-7
module COIL_RECT (ep, en, mp, mn);
inout ep, en, mp, mn;
electrical ep, en;
magnetic mp, mn, mfp, mfn;
parameter real N = 4;	// number of turns
// Calculating Rectangular Coil geometric parameters
// Calculating inductance in Hn for geometry in m
parameter real L = ...........................................;
// Average coil area in m^2
parameter real S = ..........................................;
// Coil resistance
parameter real Rl = 1;
analog begin
	Phi(mfp,mfn) <+ N*`c_MU*Phi(mp,mn)*S*cos(alpha);         // Faraday's Law
	MMF(mfp,mfn) <+ N*I(ep,en);                                            // Amper's Law
	V(ep,en) <+ Rl*I(ep,en) - ddt(Phi(mfp,mfn)) + L*ddt(I(ep,en));
Regards.
Pavel
Reply #5 - Jun 19th, 2007, 10:25am
Glad to hear you got it working; thanks for posting the working code for posterity.
