Aug 16th, 2024, 9:52am
Recording Data in DC sweep (Read 1626 times)
makelo
Hillsboro, OR
Jun 21st, 2007, 6:53am
How does one write data to a text file in a DC sweep?  I have attached the code I frequently use for writing data in transient analysis.  It works great.  The difference is that in a DC sweep I can't use the @timer function.  If I use a similar code in a DC sweep without the timer line then I just get one data point.  Can someone suggest modifications that will record the entire DC sweep?
`include "disciplines.vams"
`include "constants.vams"
module sink1(v1);
   electrical v1;                                                  //node voltage to write
   parameter string file_name = "filename.tbl";     //file name to write to
        //strings only work in some versions of verilogA
        //hardcode the filename if necessary
   parameter real T_step = 1e-9;                         //time step for writing data.
   parameter real T_off = 0;                                //time to wait before starting
   integer file_ptr;                                               //pointer to file_name
   analog begin
       @( initial_step ) begin
          file_ptr=$fopen(file_name);
       @(timer(T_off,T_step)) begin                        //at each T_step write the node voltage
         $fwrite(file_ptr, "%e %e\n", $abstime, V(v1));
       @ (final_step) begin
         $fclose(file_ptr);
Re: Recording Data in DC sweep
Reply #1 - Jun 21st, 2007, 10:13am
You could write an if statement that tests if the current point is a multiple of, say 0.1V, and then $strobe the output.  Or just $strobe it all the time and tell your simulator what steps you want it to take.
