Oct 31st, 2024, 11:03pm
How to size the cap of a sc cmfb? (Read 4968 times)
didibabawu
Jun 13th, 2007, 4:59am
I have read something about the sc cmfb in the book--'analog integrated circuit design'. there are four cap in the circuit. two of them are bigger and two smaller.
It says that the value of the smaller might be between 1/4~1/10 of the biger. I don't know why.Can anyone
tony_taoyh
Re: How to size the cap of a sc cmfb?
Reply #1 - Jun 14th, 2007, 5:54pm
I think, the big cap acts like a level shifter, and the smaller one is used to maintain the voltage in the "level shifter".
The reason to use small capacitor is to reduce the load for the differential mode.
hope this help you.
darrenxyz
taiwan
Reply #2 - Jun 15th, 2007, 12:05am
you can ref to the paper
"analysis of switched capacitor common mode feedback circuit" Ojas Choksi
it include quantitative and qualitative analysis of sc-cmfb circuit,
i think the paper is pratical in design process,
View Profile darrenxyz   IP Logged
Berti
Reply #3 - Jun 15th, 2007, 1:01am
The ratio of the two capacitors has an influence on the time required for
the cmfb to reach steady-state. The size of the capacitor connected to the
amplifier on the other hand influences the small-signal bandwidth of the cmfb.
But I also recommend to read the paper from Choksi. It includes a really
good analysis of sc-cmfb circuits.
Cheers
imd1
Reply #4 - Jun 15th, 2007, 1:36am
The paper by Choksi is good, but I think it does nto talk about the PSRR of the S-C CMFB.
As for the sizing, it's not complicated. One capacitor recharges the CMFB capacitor which is always connected to the output, so that it does level-shifting. This recharging capacitor can be as small as you'd like, if the start-up time is not an issue. You can make it larger to improve the start-up time, but then you are increasing the loading of the main amplifier (the CMFB adds the sum of the two caps to the capacitive load at the output). I have used equal capacitors, for example, and sized the sum of them to be small with respect to the capacitance at the output.
Shano
Taiwan
Reply #5 - Jun 15th, 2007, 3:16am
I just think about this question recently.
In the paper"Analysis of Switched-Capacitor Common-Mode
Feedback Circuit", it mentions that the GBW of common
signal loop should be near the GBW of differential signal loop to reduce the
distortion. When C1+C2 increase, the GBW of common signal loop increases
and the GBW of differential signal loop decreases. (Figure 7 of the paper).
C1 is the switched-capacitor and C2 is not switched.
And in Martin book, the C1 would be 1/4 to 1/10 of C2 for loading balance in two
phases.
However, I still have some doubts.
The return ratio in that paper is derived in one of the two phases.
In that paper, it is phase2.
So, the switched capacitor effect is not counted in.
I think the return ratio in that paper would be deviated from true situation.
Is it right?
Shano
