Jul 16th, 2024, 11:18am
Assura Exrtraction: Please re-generate cap_coeff (Read 3782 times)
Faisal
Jun 18th, 2007, 2:33am
I get a following error message from Assura Exrtraction
Run pax16 to generate capfile
Warning at "pax_16" cap_coeff.dat version 0 is out of date, needs to be 4
"FATAL" at pax16, Please re-generate cap_coeff.dat using latest capgen
bernd
Munich/Germany
Re: Assura Exrtraction: Please re-generate cap_coe
Reply #1 - Jun 19th, 2007, 1:15am
You are probably using an newer version of Assura than your
parasitic models are create with.
You have to run 'capgen', this is the tool to create parasitic models,
to re-generate them.
Have a look at the files 'RCXspiceINIT' or 'RCXdspfINIT', of your
Assura technology directory, in the last lines of these files the
capgen options of the capgen last run are indicated.
I also strongly recommend to read the chapter
'Assura RCX and Capgen Setup' from the
'Assura Physical Verification Developer Guide'
for better understanding.
Bernd
Just another lonesome cad guy
Faisal
Reply #2 - Jun 21st, 2007, 2:59am
Thank you Bernd, This problem got solved after updating the Assura version.
