cmarqu
in the past, we were verifying connectivity of a schematic (in Cadence Virtuoso) by netlisting it with vhdlNet, filling out the modules with models, and simulating that in the digital realm. We would map analog ports to a user-defined type in pure VHDL (a record type made from an integer value and an abstract portion), and in order to get the port types correct, we set the vhdlDataType property of each port. This worked pretty well, a port would look like
vout : out our_vhdl_type;
Now, we are moving to VHDL-AMS though, and I can't find a way to get
terminal vout : electrical;
out of vhdlNet.
The only way I see right now is to post-process the generated files, but if I can avoid this...
Any hints welcome.
Thanks Colin
