Jul 21st, 2024, 6:19pm
Generate Initial Guess for DC Solver Failed (Read 2646 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Jun 18th, 2007, 5:57pm
When I do DC analysis using Analog Artist, I always meet such sentences like this:
DC Analysis ‘dc0p’
Attempt to generate initial guess for DC solver failed.
What is going on here, how can I solve this kind of problem, or it is not a problem or something?
Rgds,
Terry
Re: Generate Initial Guess for DC Solver Failed
Reply #1 - Jun 19th, 2007, 10:35am
It's not a huge problem, as long as Spectre does eventually find a solution ... it might be taking longer than it should to find that solution.
I think Spectre tries to make a "good" initial guess for DC Newton -- a "dumb" initial guess would be: all nodes are zero, except those that have voltage sources on them.  One could attempt to improve upon this by using some heuristics to guess some other values: if you know the voltage on one side of a diode, then the voltage on the other side might be 0.6V higher.  I think the message is saying that Spectre's heuristics are having trouble with your circuit topology or some of the device models.
