trashbox wrote on Jun 25th, 2007, 3:05am:Hi all,
If I use the commond line to run spectre, for example: spectre input.scs, after the simulation is finished, how can I view the results? Where is the simulation result file? In the analog artist GUI (graphic user interface), I can use results->direct plot, however in the commond line, I have no idea about this issue.
Addtionally, in the analog GUI, I can save the state (for example, the Tran simulation stimulus).Where are these states saved, in which sub-file?
Thanks very much.
Trashbox
Hi Trashbox,
1. You specify the result format with the command line option "-format fmt" and the result file or directory with "-raw raw".
2. All settings from your state required for the simulation are added to the netlist by the netlister.
For example, the line "simulatorOptions ..." sets the parameters from the Simulation->Options->Analog dialog of the ADE.
If you use graphical stimuli, the netlister adds a line include "./_graphical_stimuli.scs" to your netlist...
BOE
