Jul 21st, 2024, 12:24pm
How can I view the spectre simulation results (Read 4908 times)
trashbox
Jun 25th, 2007, 3:05am
If I use the commond line to run spectre, for example: spectre input.scs, after the simulation is finished, how can I view the results? Where is the simulation result file? In the analog artist GUI (graphic user interface), I can use results->direct plot, however in the commond line, I have no idea about this issue.
Addtionally, in the analog GUI, I can save the state (for example, the Tran simulation stimulus).Where are these states saved, in which sub-file?
Thanks very much.
Trashbox
boe
Re: How can I view the spectre simulation results
Reply #1 - Jun 25th, 2007, 3:59am
trashbox wrote on Jun 25th, 2007, 3:05am:
Thanks very much.
Trashbox
Hi Trashbox,
1. You specify the result format with the command line option "-format fmt" and the result file or directory with "-raw raw".
2. All settings from your state required for the simulation are added to the netlist by the netlister.
For example, the line "simulatorOptions ..." sets the parameters from the Simulation->Options->Analog dialog of the ADE.
If you use graphical stimuli, the netlister adds  a line include "./_graphical_stimuli.scs" to your netlist...
BOE
kiran123
Reply #2 - Jun 25th, 2007, 4:13am
Hi ,
 for command line spectre 2 ways to see output i.e
1) using wavescan tool you can see simulation results in Gui form just like how a waveform apears in ADE just after simulation is over
for this you can type on command prompt to invoke this tool
wavescan -expr mdl &
2)Using some scripting languages like OCEAN or MDL to see the descrete values on by writing it to a file
for this you can refer corresponding user manuals
Kiran
trashbox
Reply #3 - Jun 25th, 2007, 7:56pm
BOE and Kiran,
Thanks very much for your help. It can work well.
Hi BOE,
For the state saving issue, I puzzled about your advice: If I have many states, for example state1 is TRAN, state2 is TRAN+PSS and state3 is TRAN+PSS+PNOISE. I run state3 (in this case, state3 information is included in my netlist as you said) and save state1 & state2 at the same time so that I can load them next time. In this case, where are the state1 & state2 saved? Thanks for your patience.
Best wishes!
Trashbox
boe
Reply #4 - Jun 26th, 2007, 12:48am
trashbox wrote on Jun 25th, 2007, 7:56pm:
For the state saving issue[...]: If I have many states, for example state1 is TRAN, state2 is TRAN+PSS and state3 is TRAN+PSS+PNOISE.
Hi Trashbox,
If you are using a Cadence version older than IC 5.10.41 USR3, you can view (and change) the state save directory in the ADE under Session->Options. The directory structure is <StateSaveDir>/<Lib>/<Cell>/<Simulator>/<StateName>
For IC 5.10.41 USR3 or newer, you have an alternative: you may choose saving the state as a cell view of your top level cell (testbench) instead. You select this & the save path in the Save State form, so I suppose you have an older version... Oh, and "." is the directory you started Cadence in...
Sory about the confusion...
BOE
trashbox
Reply #5 - Jun 26th, 2007, 7:05pm
Hi Boe,
Thank you very much!
Trashbox
