Aug 18th, 2024, 7:24pm
Matching problem (Read 2343 times)
jefkat
Matching problem
Jun 25th, 2007, 7:58am
Hi guys,
          I have a resistor capacitor parallel combo (100ohm || 8pF). I have to match it to 100 ohm with a return loss of atleast 19dB from 1M to 400M.
Its a challenge. Can anyone float an idea here please ?  What are the theoretical limits  in such cases ..any clues??  hope to hear some wisdom  :-)
   Cheers
   Shaf
mg777
Re: Matching problem
Reply #1 - Jun 25th, 2007, 9:33am
Where does the 19 dB come from? Is this for pulse transmission?
Off the top: the bandwidth range 1:400 is way too high, in fact the 8 pF has a 100 Ohm reactance only at 200 MHz. So you're probably looking at 100 MHz to 400 MHz, or a Q close to unity. For starters, try a series inductor of 10,000*8e-12 = 80 nH, which also gives a resonance in the right range. Or fix the resonance and fiddle the Q.
If you want a tighter performance, try a higher order Chebyshev LC ladder. But it's not worth the effort, I think.
M.G.Rajan
jefkat
Reply #2 - Jun 25th, 2007, 11:59pm
yes ,Its about pulse transmission.!
Thanks for your input.
