Sep 18th, 2024, 3:13am
How to simulate the stability of sc-cmfb using hsp (Read 1830 times)
didibabawu
Jul 01st, 2007, 7:58am
Because I can't use spectre,I need to simulate the stability of sc_cmfb circuit using hspice.
I break the cmfb point and add the equivalent load at the output of the cmfb, then using the dc point with cmfb to doing ac analysis to see the phase margin.I'm not sure whether the method is right. Can anyone give me some suggestion? Thank you very much.
boe
Re: How to simulate the stability of sc-cmfb using
Reply #1 - Jul 2nd, 2007, 3:59am
Since you use AC analysis, I suppose you have a continuous-time CMFB...
If you open the loop you have to make sure that you still get the same operating point...
BOE
