Jul 17th, 2024, 2:39pm
Pages: 1 2
Help with test bench (Read 10141 times)
slackjack
Jul 02nd, 2007, 7:25am
Hey all,
I'm currently learning verilog. I'm trying to make a test bench to
simulate a binary-to-7-segment decoder. I've broken the circuitry up
into individual logic circuits for each segment (a-g); so I have 7
logic circuits total.
I want to see how each of these individual logic circuit would respond
to a series of identical waveforms. So instead of making separate
verilog files for each of the logic circuits, I decided to dump them
all in a test bench. But in doing so, I've made some mistakes and cant
figure out what they are.
I'm not concerned (ATM) with whether the logic circuits are functionally correct, right
now I want to get the test bench up and running. Please help.
module testBench;
wire [6:0] w1;
wire w2,w3,w4,w5;
binaryToASeg  a(w1[6],w2,w3,w4,w5);
binaryToBSeg  b(w1[5],w2,w3,w4,w5);
binaryToCSeg  c(w1[4],w2,w3,w4,w5);
binaryToDSeg  d(w1[3],w2,w3,w4,w5);
binaryToESeg  e(w1[3],w2,w3,w4,w5);
binaryToFSeg  f(w1[1],w2,w3,w4,w5);
binaryToGSeg  g(w1[0],w2,w3,w4,w5);
Func_gen_and_disp  disp(w2,w3,w4,w5,w1);
module binaryToASeg	 //Segment A
	  (input b3, b2, b1, b0,
	   output aSeg);
    and g4(aSeg,~bo,~b3,b2);
module binaryToBSeg	 //Segment B
	 (input b3,b2,b1,b0,
	  output bSeg);
    and  g1(p1,~b1,b0,~b3);
    and  g2(p2,b1,~b0,~b3,b2);
    or   g3(bSeg,p1,p2);
module BinaryToCSeg	 //Segment C
	   output cSeg);
	   and g1(p1,~b3,~b2,~b1,b0);
	   and g2(p2,~b3,~b2,b1,~b0);
	   or  g3(cSeg, p1,p2);
module BinaryToDSeg    //Segment D
	   output dSeg);
	   and g1(p1,~b3,b2,~b1,~b0);
	   and g2(p2,b3,~b2,~b1,b0);
	   and g3(p3,~b3,b2,b1,b0);
	   or  g4(dSeg,p1,p2,p3);
module BinaryToESeg    //Segment E
	   output eSeg);
	   and g1(p1,~b3,b1,b0);
	   and g2(p2,~b3,b2,~b1);
	   and g3(p3,b3,~b2,~b1,b0);
	   or  g4(eSeg,p1,p2,p3);
module BinaryToFSeg   //Segment F
	   output fSeg);
	   and g1(p1,b1,~b3,~b2);
	   and g2(p2,b1,b0,~b3);
	   or  g3(fSeg,p1,p2);
module BinaryToGSeg     //Segment G
	   output gSeg);
	   and g1(p1,~b3,~b2,~b1,~b0);
	   and g2(p2,~b3,b2,b1,b0);
	   or  g3(gSeg,p1,p2);
module Func_gen_and_disp  //here is where I make the waveform and
//print the results.
	  (output reg b3,b2,b1,b0,
	   input [6:0] Seg);
initial
	  begin
		 $monitor
		 ($time,,,"b3 = %b b2 = %b b1 = %b b0 = %b, aSeg = %b,
bSeg = %b, cSeg = %b, dSeg = %b, eSeg = %b, fSeg = %b, gSeg = %b,",
			 b3,b2,b1,b0,
Seg[6],Seg[5],Seg[4],Seg[3],Seg[2],Seg[1],Seg[0]);
		 #10  b3 = 0; b2 = 0; b1 = 0; b0 = 0;
		 #10  b3 = 0; b2 = 0; b1 = 0; b0 = 1;
		 #10  b3 = 0; b2 = 0; b1 = 1; b0 = 0;
		 #10  b3 = 0; b2 = 0; b1 = 1; b0 = 1;
		 #10  b3 = 0; b2 = 1; b1 = 0; b0 = 0;
		 #10  b3 = 0; b2 = 1; b1 = 0; b0 = 1;
		 #10  b3 = 0; b2 = 1; b1 = 1; b0 = 0;
		 #10  b3 = 0; b2 = 1; b1 = 1; b0 = 1;
		 #10  b3 = 1; b2 = 0; b1 = 0; b0 = 0;
		 #10  b3 = 1; b2 = 0; b1 = 0; b0 = 1;
		 #10 $finish;
P.S. Remember that I'm new to the world of verilog, so if you have any suggestions on how to do this in a more efficient way, please do tell.
slackjack
Re: Help with test bench
Reply #1 - Jul 5th, 2007, 7:41am
No comments on this guys?
boe
Reply #2 - Jul 6th, 2007, 4:55am
Hi slackjack,
1. Verilog is case sensitive, so you can't mix BinaryToCSeg and binaryToCSeg (etc).
2. the binaryToXSeg's have their output as lat port, but in the instantiation you give the output first.
BOE.
Reply #3 - Jul 6th, 2007, 5:04am
        output aSeg);
It looks to me like you've swapped your inputs and outputs.  That is, the module declarations always have the output last, but the instantiation lines always have w5 as the last port connection, meaning all the segments are fighting to set the value on w5.
I think you need:
binaryToASeg  a(w2,w3,w4,w5, w1[6]);
etc.
slackjack
Reply #4 - Jul 6th, 2007, 6:35am
Thank you both for your responses. I've changed my code as per your suggestions.
module testBench;
wire [6:0] seg;
wire b3,b2,b1,b0;
binaryToASeg  a(b3,b2,b1,b0,seg[6]);
binaryToBSeg  b(b3,b2,b1,b0,seg[5]);
binaryToCSeg  c(b3,b2,b1,b0,seg[4]);
binaryToDSeg  d(b3,b2,b1,b0,seg[3]);
binaryToESeg  e(b3,b2,b1,b0,seg[2]);
binaryToFSeg  f(b3,b2,b1,b0,seg[1]);
binaryToGSeg  g(b3,b2,b1,b0,seg[0]);
Func_gen_and_disp  disp(b3,b2,b1,b0,seg);
	   output aSeg);
	 (input b3,b2,b1,b0,
	  output bSeg);
    or   g3(bSeg,p1,p2);
module binaryToCSeg	 //Segment C
	   output cSeg);
	   or  g3(cSeg, p1,p2);
module binaryToDSeg    //Segment D
	   output dSeg);
module binaryToESeg    //Segment E
	   output eSeg);
module binaryToFSeg   //Segment F
	   output fSeg);
	   or  g3(fSeg,p1,p2);
module binaryToGSeg     //Segment G
	   output gSeg);
	   or  g3(gSeg,p1,p2);
module Func_gen_and_disp  //here is where I make the waveform and print the results.
	   input [6:0] Seg);
initial
	  begin
		 $monitor($time,,,"b3 = %b b2 = %b b1 = %b b0 = %b, aSeg = %b, bSeg = %b, cSeg = %b, dSeg = %b, eSeg = %b, fSeg = %b, gSeg = %b,",b3,b2,b1,b0,Seg[6],Seg[5],Seg[4],Seg[3],Seg[2],Seg[1],Seg[0]);
		 #10 $finish;
However, when I compile this (on VeriLogger Pro) and still get error messages:
test2.v: L18: error: parse error, unexpected INPUT_
test2.v: L19: error: parse error, unexpected OUTPUT
test2.v: L23: error: Invalid port name
test2.v: L26: error: parse error, unexpected INPUT_
test2.v: L27: error: parse error, unexpected OUTPUT
test2.v: L33: error: Invalid port name
test2.v: L36: error: parse error, unexpected INPUT_
test2.v: L37: error: parse error, unexpected OUTPUT
test2.v: L43: error: Invalid port name
test2.v: L46: error: parse error, unexpected INPUT_
test2.v: L47: error: parse error, unexpected OUTPUT
test2.v: L54: error: Invalid port name
test2.v: L57: error: parse error, unexpected INPUT_
test2.v: L58: error: parse error, unexpected OUTPUT
test2.v: L65: error: Invalid port name
test2.v: L68: error: parse error, unexpected INPUT_
test2.v: L69: error: parse error, unexpected OUTPUT
test2.v: L75: error: Invalid port name
test2.v: L78: error: parse error, unexpected INPUT_
test2.v: L79: error: parse error, unexpected OUTPUT
test2.v: L85: error: Invalid port name
test2.v: L88: error: parse error, unexpected OUTPUT
test2.v: L89: error: parse error, unexpected INPUT_
test2.v: L110: error: Invalid port name
Finished Phase I
Process exited with code 0.
boe
Reply #5 - Jul 6th, 2007, 6:49am
And in module binaryToASeg you should schange bo to b0.
BOE
slackjack
Reply #6 - Jul 6th, 2007, 6:53am
Hi Boe,
That didn't do the trick either. Does it have something to do with how I made module Func_gen_and_disp?
boe
Reply #7 - Jul 6th, 2007, 7:03am
I tried it with the attached code. And the simulation runs...
module testBench;
wire [6:0] seg;
wire b3,b2,b1,b0;
	   output aSeg);
    and g4(aSeg,~b0,~b3,b2);
	 (input b3,b2,b1,b0,
	  output bSeg);
    or   g3(bSeg,p1,p2);
	   output cSeg);
	   or  g3(cSeg, p1,p2);
	   output dSeg);
	   output eSeg);
	   output fSeg);
	   or  g3(fSeg,p1,p2);
	   output gSeg);
	   or  g3(gSeg,p1,p2);
	   input [6:0] Seg);
initial
	  begin
		 #10 $finish;
slackjack
Reply #8 - Jul 6th, 2007, 7:11am
Thats weird. Are you using modelsim to run this?
boe
Reply #9 - Jul 6th, 2007, 7:18am
No, ncsim.
Perhaps you should try old syntax:
module binaryToASeg ( b3, b2, b1, b0, Seg); //Segment A
	  input b3, b2, b1, b0;
	  output aSeg;
instead of
	   output aSeg);
slackjack
Reply #10 - Jul 6th, 2007, 7:49am
Old syntax yields nothing.
module testBench;
wire [6:0] seg;
wire b3,b2,b1,b0;
module binaryToASeg (b3, b2, b1, b0,Seg);
output aSeg;
module binaryToBSeg	(b3, b2, b1, b0,Seg);
 output bSeg;
    or   g3(bSeg,p1,p2);
module binaryToCSeg (b3, b2, b1, b0,Seg);
 output cSeg;
	   or  g3(cSeg, p1,p2);
module binaryToDSeg (b3, b2, b1, b0,Seg);
 output dSeg;
module binaryToESeg (b3, b2, b1, b0,Seg);
 output eSeg;
module binaryToFSeg  (b3, b2, b1, b0,Seg);
 output fSeg;
	   or  g3(fSeg,p1,p2);
module binaryToGSeg  (b3, b2, b1, b0,Seg);
 output gSeg;
	   or  g3(gSeg,p1,p2);
module Func_gen_and_disp (b3,b2,b1,b0,Seg);
	  output b3,b2,b1,b0;
	   input [6:0] Seg;
initial
	  begin
		 #10 $finish;
I'll have to try this on Icarus Verilog or modelsim. This is beginning to prove very frustrating and is confusing me even more about the language.
slackjack
Reply #11 - Jul 6th, 2007, 8:02am
I've just confirmed that veriLogger pro doesnt use verilog 2001 style syntax.
boe
Reply #12 - Jul 6th, 2007, 8:27am
Hi slackjack,
I noticed you have Seg in the port list but aSeg in the output statement...
BOE
output aSeg;
slackjack
Reply #13 - Jul 6th, 2007, 9:00am
I made the changes. Does this look alright, becuase it still doesnt compile:
module testBench;
wire [6:0] Seg;
wire b3,b2,b1,b0;
binaryToASeg  a(b3,b2,b1,b0,Seg[6]);
binaryToBSeg  b(b3,b2,b1,b0,Seg[5]);
binaryToCSeg  c(b3,b2,b1,b0,Seg[4]);
binaryToDSeg  d(b3,b2,b1,b0,Seg[3]);
binaryToESeg  e(b3,b2,b1,b0,Seg[2]);
binaryToFSeg  f(b3,b2,b1,b0,Seg[1]);
binaryToGSeg  g(b3,b2,b1,b0,Seg[0]);
Func_gen_and_disp  disp(b3,b2,b1,b0,Seg);
	   output Seg;
    and g4(Seg,~b0,~b3,b2);
	   output Seg;
    or   g3(Seg,p1,p2);
	   output Seg;
	   or  g3(Seg, p1,p2);
	   output Seg;
	   or  g4(Seg,p1,p2,p3);
	   output Seg;
	   output Seg;
	   or  g3(Seg,p1,p2);
	   output Seg;
	   or  g3(Seg,p1,p2);
module Func_gen_and_disp  (b3, b2, b1, b0,Seg);
	  output reg  b3,b2,b1,b0;
	   input [6:0] Seg;
initial
	  begin
		 #10 $finish;
Thanks!
Update: I managed to get my hands on an edition of verilogger thats supports 2001 syntax, and it compiles fine. But I'm still curious as to why the old one doesnt work.
boe
Reply #14 - Jul 6th, 2007, 9:53am
I can't see why you should need Verilog-2001 for your last piece of code (reply #13)...
What error messages do you get?
BOE
Pages: 1 2
