Jul 16th, 2024, 8:36pm
verilogAMS event-OR (Read 2375 times)
Seppo
verilogAMS event-OR
Jul 03rd, 2007, 8:59am
In plain verilog,
always@(b1 or b2 or b3)
will detect changes in b1, b2 or b3.
If I write
logic b1, b2, b3;
analog begin
@(b1 or b2 or b3) blah;
The elaborator complains that the left operand of type integer is not supported for operator "Event OR".
Writing:
analog begin
@(b1 || b2 || b3) blah;
works, but it not the same.
How can I get event-OR to work within an analog block?
Seb
boe
Re: verilogAMS event-OR
Reply #1 - Jul 3rd, 2007, 11:02am
Hi Seb,
I haven't tested this, but have you tried declaring b1, b2, b3 as wires or regs instead of integers?
BOE
Seppo
Reply #2 - Aug 15th, 2007, 6:03am
It turns out that digital lines are converted to integers within an analogue block, which gives raise to the problem I commented.
The bug in verilogAMS has been solved newer versions of IUS.
