Aug 15th, 2024, 12:33pm
software (Read 2811 times)
kamath
software
Jul 23rd, 2007, 11:23pm
i am new to verilog-ams.I have learnt basics of verilog.
I have model sim with me,is it posible to run verilog-a in it or should i separately use cadence tools.Which is better.
thank you
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: software
Reply #1 - Jul 23rd, 2007, 11:58pm
For Verilog-A you will need an analog simulator: Hspice, Eldo, Spectre, and generally any commercial SPICE-type simulator will do. ModelSim will use only digital Verilog - you will need Eldo respectively AdvanceMS from the same vendor to use Verilog-A or Verilog-AMS.
ghad
Re: software
Reply #2 - Aug 13th, 2007, 2:08pm
Verilog AMS code runs perfectly on Cadence, so I recommend you to use Cadence!
Re: software
Reply #3 - Aug 15th, 2007, 9:03am
Eldo has a Verilog-A option (you don't need AdvanceMS unless you're really doing Verilog-AMS).
ghad: "perfectly" ??  Hah.
