kamath
i am designing period-controlled-oscillator,but not getting the desired output from block.please suggest any changes to be made
module myosc(in,out,clk); input in,clk; output out; electrical in,out,clk;
parameter real vh=1.5; parameter real vl=0;
parameter real vtrans=0.6; parameter real maxp=(1/5000000); parameter real minp=(1/500); integer comp; integer n; real period; real step;
analog begin
@(initial_step)begin period=(1/500000);
step=(1/5000) + $abstime; end
@(timer(step))begin n=!n; step=step+(0.5*period); end
@(cross(V(clk)-vtrans,1)) begin if((V(in)-vtrans)>0) comp=1; else comp=-1; period = period +(comp*step); end
if(period>maxp) period=maxp; if(period<minp) period=minp; V(out)<+transition(n?vh:vl,0,100p); end
