JC
Frank
Thanks for reply
I don't think there is aliasing or folding effect in the above circuit , because the thermal noise generated by the conductance is not modulated, neither the signal path from noise to output (Vpulse) is modulated.
Maybe I don't show clearly in the above circuit, which consists of a periodic pulse voltage source without noise and a resistor with the option "isnoisy=yes".
I have read that Ken's paper roughly but I haven't got the answer yet. I will read again carefully.
-JC
