Aug 18th, 2024, 3:11am
region 0 in dc operation point (Read 3347 times)
James Bond
Jul 06th, 2007, 7:59am
does anybody know 'region 0' in dc operation point mean triode region or cut off region ? I am simulatiing passive mixer, I found the four transistors are all working in the region 0 state, and I still get IF output.  But in my memory, region 0 represents cutoff state, and region 1 represents triode state, and one pair of switches of the mixer should work in the triode region, the other two should work in the cutoff state.
Best Regards
James
Re: region 0 in dc operation point
Reply #1 - Jul 6th, 2007, 3:03pm
To find out, type "spectre -hs bsim3v3" and look for the description of the region parameter. It will give a list of regions. The first listed will be region 0, the second will be region 1, etc.
James Bond
Reply #2 - Jul 6th, 2007, 3:19pm
Ken Kundert wrote on Jul 6th, 2007, 3:03pm:
To find out, type "spectre -hs bsim3v3" and look for the description of the region parameter. -Ken
Hi, Ken,
Thank you for the reply, could you kindly tell me where to input this command ?  I tried in CDS.log window, but it returns ''unbond variable -hs''
boe
Reply #3 - Jul 6th, 2007, 3:33pm
Command line (UNIX)
BOE
