Oct 21st, 2024, 9:14am
Cgd in miller effect (Read 2334 times)
RobertZ
the art of analog
San Diego, CA
Jul 10th, 2007, 11:56pm
Hi, all,
In spectre's simulation result, there are Cgd and Cdg in the operation print out, and they are different (sometimes, by a lot).
Which one should be used for miller effect? |Av|*Cgd or |Av|*Cdg shows up at the gate?
Robert
Robert
boe
Re: Cgd in miller effect
Reply #1 - Jul 11th, 2007, 1:32am
Hi RobertZ,
I think Yawei's post helps here:
ywguo wrote on Jul 7th, 2007, 12:20am:
Assume you are using BSIM 3v3 model, please take a look at the definition using spectre -h bsim3v3.
Here, cdg is ΔQd/ΔVg, cgd is ΔQg/ΔVd, cgs is ΔQg/ΔVs. So it is not curious to see minus capacitance.
Yawei
So you need cgd...
Hope this helps
BOE
