pavlosEMP
The deal here is that, i have developed an algorithm to extract some info which leads me to form an approximation of the impulse response of a circuit, which has a non linear out output.
So by considering a chosen input, we can extract an approximation of the transfer function of the circuit.
The realization of such a circuit, is now a matter of selecting the way to make it, and selecting its components.
I personally, am not in the field of electronics, so all of my colleagues, suggest that i should try a passive realization.
Anyway i have been for quite a while now to find a solution to this problem but i have understood that this impulse response is very very fast indeed, so probably, there aren't any opamps so fast, at least not in the present time.
In the attachement i give to you my impulse response function. The pairing of the nominators with the denominators, is entirely my arbitrary choice!
Thank you!
