Aug 16th, 2024, 12:26am
question about vco loaded (Read 1819 times)
James Bond
Jul 12th, 2007, 4:43am
I am simulating the vco, polyphase and passive mixer together.
I have an output amplitude 1.75Vpp from vco, after the polyphase filter,
it becomes 800mVpp. But when I connect this output to mixer, it becomes
340mVpp which is not enough to drive mixer.
It seems that a isolation amplifier would be useful placed between
polyphase filter and mixer. But I am not sure how to build this kind of
large input signal and high speed amplifier or I should use just a LC tank
network to amplify the signal?
Could you please give me some suggestions? Thank you vey much.
mobil
Australia
Re: question about vco loaded
Reply #1 - Sep 20th, 2007, 10:32pm
As u said, the buffer is needed between VCO and Mixer. And it's better to design VCO with buffer at the beginning
