leena2k6
Hi, I have recently started to develop AMS environment(Cadence Virtuoso AMS) at chip level. The testbench components are System Verilog and the design is mixed verilog + vhdl. While running verilog -irun ...command, i see some issues in ncelab. The error is something like - Hierarical component lookup failure testbench.top.......cfash0.ftop.IFLH FYI, the same pattern runs fine when run without ams options i.e without giving -propspath option in the verilog run command. Also the testbench is SV, top, cfash0 is verilog code, ftop is a vhdl code whereas IFLH is verilog. The cflash0, ftop, IFLH are all digital blocks. Any clues why do i see this issue? Thanks, Leena
