Also, you should be able to use a new version of spectre (e.g. MMSIM61 or MMSIM62) with IC5033. In other words, if you can't change the environment (for some reason), changing the spectre version should be possible. During the life of IC5141, spectre was split from the IC stream into a separate stream (MMSIM) together with Ultrasim - simply put the MMSIM/tools/bin in your path before the IC/tools/bin and IC/tools/dfII/bin .
If you're using a newer version of spectre, it will have psp included.
