Jul 21st, 2024, 6:27am
syntax of source PWL in Eldo (Read 2982 times)
Pavel
Lausanne/Switzerland
Jul 18th, 2007, 3:09am
Hello
What is the syntax of PWL sorce in Eldo that read from data from file.
Following Eldo LRM I used following command:
v1 AAA 0  PWL file = "iso14a_106m.txt"
This produces following error
ERROR   54: Syntax error parsing V1: Found  = while expecting REAL value
Where am I wrong?
Regards.
Pavel.
Re: syntax of source PWL in Eldo
Reply #1 - Jul 19th, 2007, 4:51am
Not having Eldo myself, I'd try a few variations:
v1 AAA 0 0 PWL file = "iso14a_106m.txt"
v1 AAA 0 PWL "iso14a_106m.txt"
and then I'd go read the manual ...
Pavel
Reply #2 - Jul 20th, 2007, 3:45am
Thanks Geogffrey,
Problem resolved.
The LRM that I have is for ver. 6.6.
But Eldo version that we have is 6.5. In 6.5 this syntax isn't supported.
Regards.
Pavel
