Jul 24th, 2024, 11:16am
DAC Testing without exercising all the codes (Read 3763 times)
analog2000
Jul 18th, 2007, 10:24pm
I am testing a 12 bit dac. I do not have enough memory to exercise all the 4096 digital codes.  It is a segmented architecture. It has a 6 bit R-dac and a 6 bit capdac.
So what I do is to step thru the coarse settings only which are 2^6-->64 codes. I then calculate inl/dnl. For inl, my question/concern is should I normalize the error with respect to the coarse step or should I normalize it with respect to the 12 bit level lsb. Of course, the 12 bit level lsb is lot smaller and gives me pretty bad inl. Is this valid ?
In the literature, everyone goes thru all the codes so their normalization is a no brainer, i.e. they normalize it with 1lsb of the entire converter.
Any comments ?
thanks
analog2000
boe
Re: DAC Testing without exercising all the codes
Reply #1 - Jul 26th, 2007, 8:11am
Hello analog2000,
In INL terms, basically yes. If your coarse DAC is bad in INL terms, that's what your overall DAC will be...
BOE
Reply #2 - Aug 7th, 2007, 11:07pm
Hi analog2000,
Sure you should normalize the INL to 1LSB of the 12 bit DAC. If it is pretty bad, that probably caused by poor mismatch of the coarse DAC. Now that you have not enough memory to handle all the 4096 codes, you'd better measured a part of codes each time. In one word, all codes should be excercised eventually.
Yawei
