analog2000
Hello, I am testing a 12 bit dac. I do not have enough memory to exercise all the 4096 digital codes. It is a segmented architecture. It has a 6 bit R-dac and a 6 bit capdac. So what I do is to step thru the coarse settings only which are 2^6-->64 codes. I then calculate inl/dnl. For inl, my question/concern is should I normalize the error with respect to the coarse step or should I normalize it with respect to the 12 bit level lsb. Of course, the 12 bit level lsb is lot smaller and gives me pretty bad inl. Is this valid ?
In the literature, everyone goes thru all the codes so their normalization is a no brainer, i.e. they normalize it with 1lsb of the entire converter.
Any comments ? thanks analog2000
