Sep 24th, 2026, 7:04am
event trigger  of integer and real values (Read 1997 times)
sylak
Silicon valley
Jul 20th, 2007, 2:30pm
Suppose I have a
real vout_val;
  integer logic1, logic2;
     logic1 = V(vin1) > vtrans;
     logic2 = V(vin2) > vtrans;
     @ (cross(V(vin1) - vtrans, 1))  logic1 = 1;
     @ (cross(V(vin1) - vtrans, -1)) logic1 = 0;
     @ (cross(V(vin2) - vtrans, 1))  logic2 = 1;
     @ (cross(V(vin2) - vtrans, -1)) logic2 = 0;
     // define the logic function.
     vout_val = (logic1 && logic2) ? vlogic_high : vlogic_low;
if an event happens in vin1 ==> change in logic1?.. will 'vout_val' change along with event based change of logic1 ? or should I include some statement for that to happen?
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: event trigger  of integer and real values
Reply #1 - Jul 23rd, 2007, 4:32am
Assuming the above code is inside an analog block there is no need to have any additional code with the calculation of vout_val. Any code inside an analog block is evaluated with every time-step unless it is guarded by an event.
