Aug 17th, 2024, 7:18am
HSPICE or Spectre (Read 3896 times)
Nano_Model
HSPICE or Spectre
Jul 23rd, 2007, 6:03pm
In terms of compact modeling capability (e.g. support & documentations) , which of them is better?
In general, I forgot the differences between SPICE and Spectre in terms of the way they handle a simulation...
simon2
Southampton, United Kingdom.
Re: HSPICE or Spectre
Reply #1 - Sep 23rd, 2007, 12:26pm
Hi Nano_Model,
                      if you "look under the hood" at Hspice and Spectre, you will find that for most foundat PDKs' they both use the Hspice models.
So my answer would be: neither (or both, depending on your perspective ...).
Cheers,
            SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
Reply #2 - Sep 27th, 2007, 3:07pm
Spectre is better without a question. But, it costs a lot more as well.
Ken here would be biased, considering "one of his children" is Spectre.
Jerry
Visjnoe
Reply #3 - Sep 29th, 2007, 7:17am
I wouldn't say Spectre is better than HSPICE. Here are some criteria:
1. Usability: HSPICE has a less steep learning curve. To my opinion, this is mostly caused by the fact that people
have to learn to use SKILL (LISP variant) to extract things like GBW,PM... I agree, some functions are foreseen under ADE, but it's all a bit more clumsy than just typing simple .meas statements.
2. Simulation time: I have never made a serious comparison, but I frequently run simulations using both Spectre and HSPICE (same conditions). At first sight, I would say both lead to comparable simulation times.
3. Accuracy: a while ago, I thought Spectre was more accurate, because it checks KCL, while HSPICE does not. It is however possible under HSPICE to impose this also using a .option setting. A bit odd, I agree, but it is possible to ensure KCL.
4. Silicon correlation: I have seen bugs where Spectre simulations didn't show any strange behavior, while the errors did pop up under HSPICE. However, this could also be because of differences between the Spectre/HSPICE models delivered by the foundry.
Peter
