Sep 30th, 2024, 6:14am
Bandgap voltage reference for 16b audio DAC (Read 1980 times)
hyy95
Jul 23rd, 2007, 9:21pm
  is high precision bandgap voltage reference a must for 16b audio DAC with SNR>100dB?
  if the answer is yes, how much  precision do we need? e.g. What 's the TC range? How much PSRR do we need?
  what about the  voltage reference  for 9b current steering DAC?
Thanks!
Jerry
jp314159
Re: Bandgap voltage reference for 16b audio DAC
Reply #1 - Aug 2nd, 2007, 1:04pm
No, it is not usually necessary -- the reference is basically a multiplier on the DAC digital code -- so for audio applications, it is like a volume control. No one will notice even a 5% change in audio volume.
On the other hand, you _DO_ want a low-noise reference -- else you will add distortion and (strange) noise to your output. You are going to want noise and PSRR better than your DAC to avoid degrading it.
Depending on the application, the 9-bit DAC likely does need a 9-bit (e.g. 0.1%) reference.
