Marq Kole
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/devil.gif)
Hmmm. That's weird...
Eindhoven, The Netherlands
For Verilog-A you will need an analog simulator: Hspice, Eldo, Spectre, and generally any commercial SPICE-type simulator will do. ModelSim will use only digital Verilog - you will need Eldo respectively AdvanceMS from the same vendor to use Verilog-A or Verilog-AMS.
