Marq Kole
Hmmm. That's weird...
Eindhoven, The Netherlands
For Verilog-A you will need an analog simulator: Hspice, Eldo, Spectre, and generally any commercial SPICE-type simulator will do. ModelSim will use only digital Verilog - you will need Eldo respectively AdvanceMS from the same vendor to use Verilog-A or Verilog-AMS.
