Bill Toole
Hi
I would like to implement a mux very similar to the code boe suggested for a simulation test bench where i want to set one input for the entire simulation. So instead of using a control signal i would like to use an integer parameter to select the input of the mux. Here is my code
`include "constants.vams" `include "disciplines.vams"
module 64bit_mux(inp, outp); input [63:0] inp; output outp;
electrical [63:0] inp; electrical outp;
parameter integer N=0 from [0:63];
analog begin V(outp) <+ V(inp[N]); end endmodule
However, it will not compile and i get the error message
Error found by spectre during SpectreHDL compile. "/64bit_mux/veriloga/veriloga.va", line 16: "V(outp) <+ V(inp[N])<<--? ;" "/64bit_mux/veriloga/veriloga.va", line 16: Error: The index used to access bits of analog signal vector `inp' is not a constant, constant expression, genvar variable or a genvar-constant expression. To avoid this problem, ensure that the indexes used to access the bits of analog signal vectors are constants, constant expressions, genvar variables or genvar-constant expressions.
I tried using a genvar variable but no luck. Sugestions?
Bill
BTW, I tried the same code as BOE but get the same error message as above
