Sep 30th, 2024, 2:24pm
stability analysis for differential feedback loops (Read 2879 times)
HdrChopper
Jul 26th, 2007, 7:17pm
In trying not break the loop for analyzing stability for a diff-diff opamp I tried to use the stb analysis, but found it does not allow to use more than one port or voltage source for reference (in a single-ended feedback loop one reference is enough). Consequently I found I could not use it.
Is there something I´m missing? If in fact stb cannot be used for differential circuits, is the only option (apart from breaking the loop to measure the RR) to directly measure the loop gain (a×f)?
Your comments are welcome.
tosei
Keep it simple
ACWWong
Oxford, UK
Re: stability analysis for differential feedback l
Reply #1 - Jul 27th, 2007, 1:57am
differential stability analysis is available in spectre.
do spectre -h stb for details or read this previous relevant post.
http://www.designers-guide.org/Forum/YaBB.pl?num=1170321868/1#1
Frank Wiedmann
Munich, Germany
Reply #2 - Jul 27th, 2007, 2:11am
Alternatively, you can use two ideal baluns (as decribed in http://www.designers-guide.org/Analysis/diff.pdf) connected back to back and put probes in the connections between them. Page 198 of http://eeclass.stanford.edu/cgi-bin/handouts.cgi?s=&t=1185524820&cc=ee214&action... shows how to perform an analysis of the differential mode loop gain in this way. For the common mode loop gain, put an additional probe into the Vcm branch and specify this probe in the stb analysis.
HdrChopper
Reply #3 - Jul 27th, 2007, 4:54am
Hi Frank/ACWWong,
Many thanks for your response.
tosei
Keep it simple
