Aug 15th, 2024, 3:36pm
mux-in-verilog-ams (Read 2101 times)
kamath
mux-in-verilog-ams
Jul 27th, 2007, 8:17am
hai,
i have tried this code in verilog-ams...
i get glitches sometimes in the output waveform,plz sugest some solution.Also the vtrans in the model has no use,also tell me more abt the vh,vl ie vhigh and vlow....
`include "constants.vams"
`include "disciplines.vams"
module mux(p1,p2,p3,p4,s1,s2,out);
parameter real vh=0.75;
parameter real vl=0.75;
parameter real vtrans=0;
output out;
input p1,p2,p3,p4,s1,s2;
electrical p1,p2,p3,p4,s1,s2,out;
analog begin
if ((V(s2)-vtrans) <= vl && (V(s1)-vtrans) >= vl)
V(out)<+V(p1);
if ((V(s2)-vtrans)<=vl && (V(s1)-vtrans)>=vh)
V(out)<+V(p2);
if ((V(s2)-vtrans)>=vh && (V(s1)-vtrans)<=vl)
V(out)<+V(p2);
if ((V(s2)-vtrans)>=vh && (V(s1)-vtrans)>=vh)
V(out)<+V(p3);
boe
Re: mux-in-verilog-ams
Reply #1 - Jul 27th, 2007, 9:36am
Hi kamath,
Some comments after a quick look on your code:
1. Contribution statements (using "<+") add up if more than one is active at the same time. For your parameter set (vl=vh), this is the case for V(sX)-vtrans = vl. I suggest you use "if then else"...
2. It should be (V(s1)-vtrans) <= vl in the first if statement.
3. I suppose vtrans is a hysteresis? Then you need different signs for high and low.
4. You could try something like this: http://www.designers-guide.org/Forum/YaBB.pl?num=1184970208/0#0
BOE
