Aug 15th, 2024, 12:35pm
count (Read 1947 times)
kamath
count
Jul 29th, 2007, 8:13am
could nebody explain the use of pulse_shape and pulse_clock and the general working of the prog
`include "disciplines.vams"
`include "constants.vams"
`define N_Counts 5
`define N_offset 0
// Counter counts N_Counts and provides a pulse every N_offset counts
// Pulse is width of clock
module Counter1(rst,clk,out);
   input rst,clk;
   output out;
   voltage rst,out,clk;
   parameter real max_out = 1.2;
   parameter real edge_time = 0;
   real vout,clk_pulse;
   integer count,clk_shape;
   analog begin
       @(initial_step) begin
          count = -1;
       @(cross(V(rst)-0.6,+1)) begin
          count = -1;
       @(cross(V(clk)-0.6,+1)) begin
          count = count + 1;
          clk_shape = 1;
          if (count > (`N_Counts-1))
                count = 0;
          clk_pulse = (count == `N_offset) ? max_out : 0;
       @(cross(V(clk)-0.6,-1)) begin
          clk_shape = 0;
       V(out) <+ transition(clk_pulse*clk_shape,edge_time,edge_time);
boe
Re: count
Reply #1 - Jul 30th, 2007, 4:23am
Hi kamath,
count cycles between 0 and `N_Counts-1 on rising edges of V(clk):
	    count = count + 1;
		    count = 0;
clk_shape is 1 while V(clk) > 0.6 (set to 1 at rising edges of clk [@(cross(V(clk)-0.6,+1))] and back to 0 at the falling edges [@(cross(V(clk)-0.6,-1))]...).
And clk_pulse goes to max_out when count == `N_offset, so you get a pulse (with length = high phase of clk) to max_out every `N_Counts clcoks.
BOE
