kamath
could nebody explain the use of pulse_shape and pulse_clock and the general working of the prog
`include "disciplines.vams" `include "constants.vams" `define N_Counts 5 `define N_offset 0 // Counter counts N_Counts and provides a pulse every N_offset counts // Pulse is width of clock module Counter1(rst,clk,out); input rst,clk; output out; voltage rst,out,clk; parameter real max_out = 1.2; parameter real edge_time = 0; real vout,clk_pulse; integer count,clk_shape; analog begin @(initial_step) begin count = -1; end @(cross(V(rst)-0.6,+1)) begin count = -1; end @(cross(V(clk)-0.6,+1)) begin count = count + 1; clk_shape = 1; if (count > (`N_Counts-1)) count = 0; clk_pulse = (count == `N_offset) ? max_out : 0; end @(cross(V(clk)-0.6,-1)) begin clk_shape = 0; end V(out) <+ transition(clk_pulse*clk_shape,edge_time,edge_time); end endmodule
