Jul 19th, 2024, 10:15pm
Insert complex impedance in Spectre. (Read 3847 times)
Mosieur_Oiso
Jul 31st, 2007, 2:20am
Is there a way to insert a complex impedance in Spectre Z=R+jX without using caps or inductors? If not, how can I insert a delay line for pss simulation? (simulation always fails when using tline from analogLib)
ponymony
Re: Insert complex impedance in Spectre.
Reply #1 - Jul 31st, 2007, 3:44am
I have also tried to simulate a delay line in pss simulation with VerilogA "absdelay" but with no success.
Error message:
Error found by spectre during periodic steady state analysis `pss'.
   The component for_uri_delay is not supported in PSS analysis because it is a behavior module component with hidden states. Components with hidden state are not allowed with
this analysis -- analysis skipped.
Reply #2 - Jul 31st, 2007, 5:26am
Mosieur_Oiso wrote on Jul 31st, 2007, 2:20am:
R+jX is non-physical, unless you're also adding R-jX.  You might be able to use a dependence source with num,den polynomials.
Reply #3 - Aug 27th, 2007, 2:12pm
You can use "mtline" these days in PSS - so you could try that.
As Geoffrey points out, a complex impedance is non-physical, and so simulating that in the time domain would be non-causal - and would present all sorts of trouble for the poor simulator. So you can't directly do it. It is possible these days to specify a port with complex impedance, but there was a problem with doing this in the RF analyses (even in harmonic balance) - I don't know whether this has been resolved yet (I've not checked).
