Jul 20th, 2024, 6:29pm
digital blocks in Eldo (Read 1240 times)
Pavel
Lausanne/Switzerland
Jul 31st, 2007, 8:31am
Hello
Is there simple way to modelize in Eldo digital block that has inputs/outputs in form of buses.
Should I declare .subckt interface as series of scalars or existe some sort of simplification, providing using of buses.
The same question concerns boolean operators - are they capable to operate with buses.
For example, if my block has 2 8-bit entries A and B, and output C, that is logical AND of A and B, what could be Eldo syntax of such subcircuit.
Regards.
Pavel.
