Jul 20th, 2024, 4:23pm
mismatch analysis using Monte Carlo (Read 2203 times)
gayu
Florida
Jul 31st, 2007, 11:34am
While doing montecarlo simulation, I could see the variation in parameters during process variation but not during the mismatch analysis.I was looking into the Cadence's Known problem and solutions guide. Corresponding to this I created a subcircuit for my nmos as
inline subckt mosmod (d g s b)
parameters du0_n_12_hsl130e= m1*(-0.000045)+ m5*(-0.000015)-0.00002
parameters dpu0_n_12_hsl130e= ((m3+m4)/2)*0.000000000000000025-0.000000000000000025
parameters dpvth0_n_12_hsl130e= ((m3+m4)/2)* 0.00000000000000004-0.00000000000000001
mosmod (d g s b) n_12_hsl130e
model n_12_hsl130e bsim3v3 type=n
ends mosmod
where I vary m1-m5 inside the mismatch block of statistics block. I'm getting an error message saying Bad subckt mosmod..
Re: mismatch analysis using Monte Carlo
Reply #1 - Aug 1st, 2007, 4:57am
Looks to me that the parameters of the inline subckt aren't actually being used...
So, first thing to try is to delete those parameter declarations and see if that works.  If so, then check your parameter declarations (especially the correct way to reference values from the statistics block); if not, then check the syntax of inline subckts.
