Hello
Had somebody experience in description of digital behavior in Eldo.
This topic isn't properly treated in Eldo LRM.
I tried simple example aiming logical AND using logical expressions
Code:* digital test
vd0 IN0 0 PATTERN 1 0 0 1n 1n 1u 10011011011101 R
vd1 IN1 0 PATTERN 1 0 0 1n 1n 1u 10001100110110 R
e1 OUT 0 VALUE={V(IN0)==1 && V(IN1)==1}
.TRAN 10u 10u
.TEMP 27.0000
.OPTION
+ ASCII
+ PSF_MULTI_BACK = 0
.PROBE V
.END
This produce folllowing errors.
ERROR 234: OBJECT "E1": Syntax error in the expression{ V ( IN0 ) = = 1 & & V ( IN1 ) = = 1 }Regards.
Pavel.
