Sep 27th, 2024, 10:21pm
question about dsm simulation (Read 914 times)
min
Aug 02nd, 2007, 2:40am
Hi :
  I have simulated a third order one bit delta sigma modulator , the input signal is 20KHz,but after simulation i found  the fft result contain a dc component. I don't know what cause this dc component.
 and I think delta sigma modulator do good to the SNR, but due to nonlinear (like switch capacitor circuit nonideal )cause THD worst.  Is that right?
 and I also want to know doing a 16 bit delta sigma modulator, usually how much THD equal ?
        Thanks!
fran2k5
Re: question about dsm simulation
Reply #1 - Aug 3rd, 2007, 2:39am
if the bit stream at the output goes from 0 to Vdd you will have a dc component due to the fact that the average power is not 0.
About the THD I think that there is not a general rule. It depends on how good is your design.
fran2k5
