Aug 15th, 2024, 12:41pm
Problem with flicker_noise and white_noise (Read 2524 times)
feihudui
Aug 02nd, 2007, 7:25am
hallo,
i have just tried to add white noise to the resistance model with Verilog-Ams, so my code
`include "constants.vams"
`include "disciplines.vams"
module restest (p,n);
inout p,n;
electrical p,n;
electrical pi;
parameter real r=1.0k;
analog begin
V(p,pi) <+ I(p,pi)*r;
V(pi,n) <+ white_noise(4*`P_K*$temperature*r,"thermal");
but it does not work. If i removed the noise statements, it functions. Analog, i want to bring flicker_noise to my VCO model. I have the same problem.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Problem with flicker_noise and white_noise
Reply #1 - Aug 2nd, 2007, 8:31am
Is the noise meant for small-signal noise analysis? white_noise will only give a result in a SPICE .NOISE analysis (or equivalent in other simulators.
B.t.w.: You can use a single branch instead of one with an internal node:
V(p,n) <+ I(p,n)*r;
V(p,n) <+ white_noise(4*`P_K*$temperature*r,"thermal");
That saves an internal node...
Reply #2 - Aug 6th, 2007, 6:28am
Marq is correct; I suspect actually that the internal node is causing trouble in this case (though it shouldn't).  The curious thing about the contribution operator (<+) is that it accumulates; it's not an assignment.
You could also try the conductance formulation:
I(p,n) <+ V(p,n) / r;
I(p,n) <+ white_noise(4*`P_K*$temperature / r,"thermal");
