morozmoroz
![](https://designers-guide.org/forum/avatars/baby.gif)
I need everything be in behavior:)
Ukraine, Kiev, Melexis
Hi, everyone! As you probably know designers use in complex design global nodes (vdd!, gnd! etc.) - that means that block often doesn't have vdd, gnd pins. But when i create model for this block I would like to sense these nodes. So, question is - is any posibility to use global nodes in VerilogAMS? I use Cadence AMS Designer. The only way I know for now is to use parameters, but it is not very convenient. Thanks is andvance!
