Oct 31st, 2024, 7:22pm
typical/worst/nominal corners of Parasitics (Read 2174 times)
skas20
Aug 02nd, 2007, 9:00pm
I have seen most of the time that any FAB, provides minimum three decks for parasitic extraction.
they are mostly typical,nominal and worst. (we receive different decks for all)
Could someone help me to understand what is the difference between them?
They differ in modelling of the parasitics? How do they model the difference?
SK.
ayowchen
Re: typical/worst/nominal corners of Parasitics
Reply #1 - Aug 4th, 2007, 8:22am
Which foundry are you using? I don't find such corner cases in TSMC,SMIC...etc.
I think the difference is from the following variation.
1.) Metal thickness
2.) Dielectrics layer thickness
The rule deck can be generated by a field solver by the above specs.
skas20
Reply #2 - Aug 11th, 2007, 1:37am
Ok. Thanks.
I am using Samsung PDK. (It has these three decks.)
Do anybody have any material on HOW a parasitic extraction tool solves the 3D layers and comes with a netlist?
-- SK.
