Aug 17th, 2024, 7:20pm
power gain vs voltage gain (Read 1572 times)
new_guy
Aug 03rd, 2007, 12:45am
There are some basic concepts which i'm still don't fully understand.
I know that from the from the antenna to the LNA we are always interested in power gain(spara matching) but from between the LNA and MIXER, we talk about voltage gain. Why is this so???
Thanks.
Regards.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: power gain vs voltage gain
Reply #1 - Aug 3rd, 2007, 2:09am
As you say power gain is related to matching, since matching networks are difficult to implement in a IC(transmission lines are huge-although recently for 60GHz designs they are starting to implement them integrated-, L,T,Pi matching networks needs passives(inductors) that are also very large in terms of area) once you deliver the maximum power to the LNA using an off-chip matching then you don't usually try to maximize power transfer between blocks, you just  make a voltage amplification.
Hope it helps,
new_guy
Reply #2 - Aug 4th, 2007, 1:04am
Hi didac,
Thanks for your views. Got it.
Newbie
