dpx4086
how to change the value of this fundamental tone 1 ???
i try to run pss simulation for a lna , the frf is 2.4GHz which is set in analysis environment , when i click "OK",it says that the value should be "small", but i cannot change the value type ,the menu of value type dose not work when i click it.
could any body tell me how to deal with this ??? thank you.
