Dec 15th, 2025, 9:50pm
rookie question: simple model in simulink (Read 5525 times)
LL
California
Aug 05th, 2007, 1:39am
This is a rookie question because I'm rather new to simulink.  I'm anlyzing error sources in ADC architectures and want to start with building a simple flash ADC in simulink.  Off the back, I can't find a simple comparator block.  I suppose I can start modeling the compator myself but I'm rather suprise there isn't one in the library ... at least not one I was able to find.  Is there a compator block in the lib? If yes, where?
thank you!
ACWWong
Oxford, UK
Re: rookie question: simple model in simulink
Reply #1 - Aug 5th, 2007, 4:17am
using basic simulink library blocks do a comparator you could use:
"Add" block for the input with rule (+-). A "Constant" block as the reference (-) input to the "Add" block
"Sign" block as the comparator decision
"Gain" block on the output to scale the comparator output
or something like the "Compare to Constant" block if you want a 0 or 1 output.
LL
California
Reply #2 - Aug 5th, 2007, 9:17pm
ACWWong wrote on Aug 5th, 2007, 4:17am:
From your reply, I'm taking that a comparator block isn't part of any library in Matlab. Thank you for the reply.
Visjnoe
Reply #3 - Aug 8th, 2007, 11:50pm
Hey LL,
when developing models in Simulink you're sometimes a bit limited by the functionality of the blockset. But this can be solved easily, because Simulink allows you to include blocks which execute MATLAB code, which can be as complex as you want.
So if you don't find a comparator in the Simulink blockset (although I think there is one), you can write some custom MATLAB code to perform the comparison.
Peter
