Sep 29th, 2024, 8:27pm
Latchup because of Capactive Coupling? (Read 1068 times)
Faisal
Aug 05th, 2007, 11:06am
Hi
1) Is it possible in some way to simulate / observe latch up problems in Cadence occuring because of transient capacitive coupling currents i.e. Cgb, Cdb, Csb etc.
e.g. If there the normally reverse-biased diodes in the MOS transistors get forward biased, Spectre  issues a warning but there is no warning for transients currents pumped into the bulk..
2) How can I find out in my simulation setup that latch up will really occur in silicon?  (all the diodes in MOS transistors are reverse-biased)
Kind Regards,
Faisal Mateen.
