hpham
HI, I'm using vpulse to set up binary inputs for my DAC simualtion (5 bits). As a result, when input is changing from 00000 to 11111, my current output change from 0 to 1mA in 32 steps, but then it goes back to 0 again, like a see-saw teeth. Is there a way to set up binary input going a circle so I can see a sine-wave output from the DAC?? thanks for your help ha
