Jul 20th, 2024, 10:14am
Cadence - Frequency Response (Read 2918 times)
Mikey
Aug 07th, 2007, 10:20am
The intention is to simulate a frequency response of a mixed signal system.  Doing the usual ac sweep is not possible.
I have obtained a impulse response for my mixed signal block. This is a time domain representation.
I can perform a dft using the cadence calculator. How do i get a magnitude and phase response plot
from the latter?
I hope cadence could support this query?
Mikey
aamar
Re: Cadence - Frequency Response
Reply #1 - Aug 9th, 2007, 1:02am
Hallo,
I can understand from your question that the case you have includes an analog signal and a digital clock signal, (something like switched capacitor circuits). Then the suggestion would be the PSS and PAC simulations. There is already a guide for this tool under the following link
http://www.designers-guide.org/Analysis/sc-filters.pdf
best regards,
aamar
