Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 5:26pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› One stage LNA with MMIC invert phase?
Previous topic
Next topic
One stage LNA with MMIC invert phase? (Read 1782 times)
imett
Aug 09
th
, 2007, 7:15am
Hi to everyone,
i'm an unskilled engeneer in RF solution, i've make my first LNA with a MMIC (like avago or HP MSA0886).
The simple LNA have a one stage amplifier but with my lecroy oscilloscope i've see that the signal is inverted, i've make some mistake or it is usual have this invertion?
Mi goal is design a peakdetector for 1GHz, so the simple idea is use an amplifier and a zero bias schottky diode (HSMS285C).
Thanks in advance.
matteo
IP Logged
ACWWong
Oxford, UK
Re: One stage LNA with MMIC invert phase?
Reply #1 -
Aug 9
th
, 2007, 8:02am
yes, for a single stage common-source amplifier, you would expect the signal inversion (as the gate voltage increase, the device takes more current, which develops more voltage across the load from Vsupply, so Vout decreases).
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
