Sep 22nd, 2026, 2:47am
process variation of BJT Vbe (Read 3031 times)
vivkr
Aug 10th, 2007, 12:20am
I was wondering what process variation would affect Vbe most and how one could see this in simulations? I am assuming that the
BJT is diode connected and the temperature is constant.
Typical simulation models for BJTs group the process corners based on transistor beta into (low-beta, high-beta).
However, beta does not seem to have an obvious connection to Vbe.
Large Vbe => Small IS => Smaller area A, Larger base width Wb
Large beta => Smaller beta
There are other process control factors such as the doping and diffusion constants etc. which are also responsible in both cases.
However, area A has a very significant contribution in deciding Vbe, whereas it has no role to play in beta which is dependent
largely on Wb (recombination in the base).
So, how can I find out conditions in simulation which show me the largest variation of Vbe around its mean when I vary the process
parameters?
Vivek
ACWWong
Oxford, UK
Re: process variation of BJT Vbe
Reply #1 - Aug 10th, 2007, 1:16am
This is achieved by variation of Is.
In BJT (Gummel-Poon, can't remember if vbic is the same) models I have used in the past, typically beta and Is are the process variables available in design kits to model process corners. Given fixed current, area and thermal voltage, vbe depends on Is (with a ln(I/Is) function i.e. Ebers-Moll equation).
vivkr
Reply #2 - Aug 10th, 2007, 1:34am
Hi ACWWong,
It is clear that Vbe is a function of Is. My question is: given the process corner models which are typically betalo, betahi,
can the min./max. condition for Vbe also be simulated. Clearly, these corner models give min./max. beta, but not directly
min./max. Vbe.
So, if you were using these models to build a clamping circuit where the BJT-based diodes must clamp a cerain node to less
than a certain voltage at a given current, you would want to know exactly how much Vbe varies. How can one simulate this?
Thanks & Regards
Vivek
ACWWong
Oxford, UK
Reply #3 - Aug 10th, 2007, 3:09am
I would say no, if only beta max/min is available, then vbe variation is not modelled...
If you have the process variation measured data for vbe for fixed current, temperature & emitter area, then you could modify Is or emitter area to match the data you have. Without the process data, you would be guessing... you'd need to seek information from your foundry...
Anyway, although nominal (at fixed temperature) Is variation is typically quite large, its impact in my experience is generally less than temperature over say a range of +/- 50K from 300K (vbe would be ~ +/-100mV)... but again it depends on the process.
vivkr
Reply #4 - Aug 10th, 2007, 3:40am
Thanks for the feedback. I will check with the foundry. However, +/-100mV does seem a lot to me. I would have thought that Vbe for a BJT
(not a parasitic one, but a proper one) would vary much less than that, less than +/- 50mV even. But, let's see.
Vivek
ACWWong wrote on Aug 10th, 2007, 3:09am:
ACWWong
Oxford, UK
Reply #5 - Aug 10th, 2007, 3:50am
BJT vbe is often quoted in text books as -2mV/oC. I have found in the techonologies I've used in the last decade its normally between that and -1.5mV/oC
vivkr
Reply #6 - Sep 20th, 2007, 12:55am
I think the -2 mV/K is also a function of the exact BJT junction properties (junction area),
but more importantly of the current density. If the current is changed, then the Vbe drop with temperature
is different. Bob Pease wrote a very good article "What's this VBE stuff anyhow?". You can find it
on his website.
Vivek
